Audiovox cruise control install? Anyone do this?
I've got a 2000 4.0 manual and I need info on where the VSS (Vehicle speed sensor) is located so I can tap into the wire (if you know the color that helps to).
In checking the tech library it looks like the tach wire is off the PCM (power control module) which should be mounted on the passenger side firewall/fenderwell and should be a brown or tan wire with a yellow stripe.
If anyone has a webpage or pictures that would help too. I plan on taking photos for anyone else that might need them.
