Best deal on custom axles???
UrbanRedneckKid
Cass Co, Missouri
I just had my 9" cut down. 79 BB 31spl cut to 60". It was only cut 2.5" on each tube, and to have my shafts cut and resplined, 4" per side must be removed.
I've been looking for a good place to buy shafts and all I've really come up with is Moser Custom Alloy Axles.
Are there more options that won't break the bank?
Yeah I was gonna recommend Moser. Is there any reason for narrowing to that width? Is it EB width? I'm sure other companies offer EB length 9" shafts, which may be cheaper than having your stockers cut and resplined. Well maybe not cheaper, but another option anyways.
Stock 8.8 width is 59", I went a half inch wider on each side. And since I have about 10" of lift, a little wider can't hurt.
When I was searching for EB dimensions I couldn't find s***. So I went with the previously mentioned idea.
BTW, I've since found the EB shaft sizes...:buttkick:
Length- 26 15/16" & 29 5/16" Bolt Pattern- 5 X 5 1/2" Rear Type- 9"
Do they only offer the custom alloys? I think they can cut down n respline your stock shafts, that's why I was gonna suggest them. You could get a set of Dutchman shafts is you want alloys. That's what I did with my 8.8, they build them to your specs, EXACTLY, so make sure they're correct. They make you send in an order form, so it takes a little longer, but they have decent pricing (I thought).
dutchmanmotorsports.com
...and to have my shafts cut and resplined, 4" per side must be removed.
My housing isn't cut narrow enough to have my shafts cut. 78+^ 31spline 9" shafts taper down after the splines and down go back to resplineable width till 4" from the end.
