- Aug 12, 2009
- '89
For most purposes, 192k/s is transparent with most audio formats, and universally accepted as a good rule of thumb with MP3 encoders.
By 'transparent' I meant blind listening tests showed that one can't tell the difference between it, and the original (cd quality). A CD's typical bitrate ) is around 1500k/s @ 44.1KHz... if I remember right. There's some minor variances, but don't worry.
Enough technobabble, unto the 'do' part.
EAC's already been recommended. Use it. It's the absolute best way to ensure you have the best possible starting point getting from the CD to your hard-drive to start compressing/encoding things from there.
If you can only play back MP3s, stick with ~224k/s except where you stereo equipment is showing fizzle -- in that case, 256k/s or a suitable VBR (variable bit rate) encoding will work fine. 320k/s is when you're wasting space.. the difference between 256k/s and 320k/s with MP3 is extremely insignificant, and I haven't found anyone yet that could tell the difference. Now, 192k/s on a good stereo, you'll get some crackle and fizzle here and there from the loss -- your good coverage of the spectrum and tweaking to ensure maximum input/output accuracy are working, that's all.
If you have a choice besides MP3, try to use a similar bitrate AAC (HE-AAC, specifically) VBR mode or Vorbis (ogg) format. Either of them has its ups and downs in its own ways, and you oughta conduct your own research into what suits your needs, and what will work best for your situation. Regardless, either of them offers more advanced features than MP3, in almost every department -- their main downside, I'll warn you now, is hardware/software support for playback.
If space isn't at all a problem, use a lossless format like FLAC or Monkey's Audio.
Remember, it's what you hear, not the other guy. Sorry if this dragged on a bit, I tend to get too technical.
More reading is always available over at http://www.hydrogenaudio.org/forums/
