lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- 5.0L
- Total Drop
- 4”
Well, the time has come where dad has decided to part with his dump trucks. His physical condition has gotten to the point where he can no longer operate a manual transmission truck, so he's been out looking at automatic F-250 diesels for himself, and intends to hang a for sale sign on both dump trucks.
As much as I'd like to keep both in the family (they've been well maintained), I don't think I could afford to keep both along with all my other trucks, so I'm forced to pick one and the other will be sold. I'm being pushed for a decision and I'm just not sure, they both have good and bad points. So I'm looking for some input.
1989 F-350 xl: Has a good trac-lok rear, dually, 460 factory rebuilt at 30k miles by Ford, HD manual 5-speed trans, 4.10 gears, 2wd, dark blue.
Pros: current inspection, new tires all the way around, new rear leaf spring hangers/shackles, new tie rod sleeves, new hoist hydro lines, new brakes all around, new rear brake cylinders and hard lines on the axle.
Cons: bed will likely last another year at best (it's got patches on patches and held together with a lot of luck and construction adhesive), there's a problem with the firewall flexing when you operate the clutch, I think the master cyl might be going bad, cab corners are starting to rot, radius arm frame mounts need replaced, 102k miles on truck, has an odd backfire issue (it'll randomly backfire, usually happens letting off the gas but not always, and sometimes will backfire under a load).
1994 F-350 xl: Dually, (I think it has a trac-lok rear), 460, HD 5-speed manual, 4.10 gears, 2wd, dark blue
Pros: Newer truck, bed has some holes, but has never been patched and likely could be easily repaired, tires in decent shape but not new (I'd say about 70% tread, maybe a lil better)
Cons: It's been sitting for 3-4 years now because the motor died (it'll need all new brake lines, new clutch line, new rear fuel tank skid plate, probably need new shocks and brakes, hydro lines never been replaced), front fenders are rotted through, truck never ran as good as the '89
Additional Info: I have a line on a rebuilt, never started 460 that was built to performance specs (around 512 ci, IIRC) for around $800-1,000. Both trucks have good interiors and the cabs are largely in excellent shape.
