- Jul 27, 2009
- Cincinnati
I'm really not sure what I want to do this point with my 1994 Ranger.
I just had a used car inspection done by a good local mechanic shop on my truck, and the results are lease than pleasing.
First off, I only paid $700 for this truck. I figured for a running, driving (daily at that), working 4x4, and probably 99% rust free body, it was worth that. My current daily driver at the time got totalled, so now I drive this truck everyday.
Here is what the truck needs after the inspection (suspension-wise):
-All the ball joints are completely ruined
-front wheel bearings are loose
-Leaf springs are completely detached at the rear shackles and the ends of the leaf springs actually rusted through (the rear most ends) and stayed in the rusted out shackles.
-Shocks are rusted through
-axle u joints are rusty but tight
-middle u joint in front axle has play
-brakes pulsate
-most of frame to body bushings are wasted
-rear brake pads are cracking & wheel cylinders are leaking
Keep in mind that I drive this truck daily and it really runs and drives ok. I've driven it to Toledo from Cincinnati, and also drove to Plymouth, MI to pick up a T56 in the condition that it's sitting in now.
My question(s) are are there any front suspension kits available (good quality stuff, not junk) and what should I do about the rear leaf springs? I wouldn't mind putting a nice skyjacker kit on this truck at some point, so can I run skyjacker 6" lift rear leaf springs out back?
I plan on buying a complete shackle and bolt kit for both sides of the leaf springs. Problem is that now the leaf springs need replaced as well.
What would you guys do and what parts would you use to fix it?
Keep in mind, I'd actually like to keep this truck for a long time as the body and interior are in great shape, and having 4x4 and a truck even have been really nice with moving and making trips for mustang parts.
-brakes pulsate
