- Aug 25, 2009
- Age
- 63
- Orwigsburg, PA
Here's what I have done so far:
Let the engine warm up to normal operating temp.
Shut it down.
Hooked up my timing light.
Disconnected the SPOUT connector.
I started the engine and checked the base timing.
I was around 15 degrees BTDC ... A little ahead ,I know.
Then I reconnected the SPOUT connector and the base timing did NOT change. It doesn't even change when you rev it or hold an idle at 2,500.
I remember reading in ALLDATA that if the ICM is bad it MAY do this to keep the engine running.
My question is this:
Is the ICM bad or is this more of a PCM issue.
Shut it down.
