more things to fix
PaleBlue90
Boosted (Not Stock)
Aurora Colorado
ok, so my 4.0 still isnt happy. it chuggs and is very sluggish from idle to 2700 rpm. once it his 27K it comes to life.
i have a CEL that comes and gos. it has thrown code 177 and 176. it comes and gos. i have not found any vacume leaks. if i run a tank of high gread fuel and injector cleaner its clears up till that tank is gone.....
i have replced the following
air filter
fuel filter
plugs
plug wires
coil pack
Have you cleaned tha MAF, or put it on a cuomputer for testing?
X2... Ck the MAF that would cause the lean condition and the rev problem because it's lean
yes i cleaned the MAF with the mass airflow spray. it helped but didnt fix the issue
