How to tighten parking brake?
JackLikesTrucks
Akron, Ohio
Seriously. In another thread I replaced all the parking brake cable and have new shoes, drums, hardware, etc. And all is exactly is it should be installed and star adjusters adjusted.
But the p brake goes to the floor just to hold the truck on a grade.
Is that normal? Cause if there's a bed load, uh bye-bye. She's not holding.
I'd like to have full-lockup of the wheels with half-down parking pedal.
Not half-lockup with full-down pedal.
Any ideas?
The e-brake pedal has a ratcheting mechanism behind it... If it's ratcheted up as much cable as it can already, that means your adjusters weren't out far enough.
myne did the same when i replaced the break shoes... but i just drove it around for a while and the adjusters adjusted and now its fine.
Un-ratchet the ebrake cable...
back your adjusters as far out as you can and still barely get the drums on, then re-ratchet in the cable.
Here's the problem. On an '02, there is no ratcheting anything anywhere. The cable are a set length and there is no turnbuckle or any adjustment anywhere.
What I did do was ratchet out the star adjusters till the drum drags and thenpumped the brake and the ebrake a few tiime to "seat" the brakes to dead center when floating. When there was any extra play from centering, I tightenened up the adjsuters till they dragged slightly. Did this 2-3 times until there was no change either side, the cable was without slack.
Found the problem.
The driver side horizontal bar came out of its place against the shoes and fell to the bottom the drum area. No damage other than a bent bar. Had to get another one.
Put all the harware back to factory positions, on both sides, reset the star adjusters and the parking brake pedal now grabs at 1/3 the way down and is in hard lock on the brake at 1/2 the way down. Very pleased.
Thanks for all your helps. Glad the factory design still works when everything is right.
