how to chang shocks 2003 ford ranger
Profile says 2003 edge...
Get front of truck on jackstands, unbolt top shock nut, unbolt lower shock bolts(under control arm), slide shock out of truck, slide new one in, bolt bottom first, then top. Done up front.
Rear: remove the bolt from the axle, pop shock out of axle mount, unbolt nut off the top mount, wiggle shock off. Install is reverse.
