1st gen seats in 2nd gen Ranger?
supz
Do 1st gen seats bolt up directly to a 2nd gen ranger? or are the holes drilled @ different floor locations?
1st and second gens are same. makes sure the seat tracks are from the same cab, regular, extended, exc.
no wonder why these extended cab tracks won't fit on my standard cab without drilling 4 extra holes lol .... so, here's a follow up question! will 60/40 seats for regular cab have the same tracks/brackets (total of 2 holes in floor on each side) as the bench seat I currently have? Ty for your help
a bench seat only uses 2 tracks total (where buckets have 2 each) so you are gonna be missing a total of 4 holes. from what i hear, the holes are there, they just need to be threaded. now keep in mind that you can swap tracks from one seat to another, so if you find an extended cab at a yard with seats you like, you can put regular cab tracks onto those seats to make them fit on your truck.
swapping tracks actually makes a ton of different seats fit in. older escorts, mustangs, explorers... http://www.therangerstation.com/tech_library/Seats.html
