- Aug 6, 2007
- Age
- 37
- Guilford, CT
When I drain at 3000, it's definitely browner than when it went in. I don't know if that's my motor wearing or the PCV or something else making it dirty.
That's all the byproducts of combustion in the engine that the oil cleaned up. It's the reason you ave to change the oil in the first place: it gets dirty. Doesn't matter what kind of oil you use, it will get dirty.
Older engines shouldn't use oils such as Mobile One as it, among others, does not have Zink in the oil. So even though the Mobile one will suffer more heat and still lubricate it will NOT fill in worn places and slow the wear in an older engine.
Most modern, if not all, oils will preform similiarly in newer less worn engines. With or without the zink. However with an older engine always look for the Zink.
This is absolute nonsense. Mobil 1 has just as much zinc as any other SM, GF-4, rated oil today (which addmittedly, is not much.) EVERY oil that has the GF-4 spec written on the bottle has a reduced amount of zinc. And just about ALL oils today (conventional AND synthetic) have the GF-4 spec, except diesel-rated oils.
So, thicker oil gives less wear supposedly, right?
Maybe running the 10-40 might not have been that bad.
What is the proported advantage of using the "lighter," lower viscosity oil?
Lighter oils flow better and get distributed throughout the engine faster, especially at startup. Thicker oils like 10w-40 are not necessary and shouldn't be used in factory Ranger engines IMO.
Oh yeah, high temperature protection is the only advantage all right...never mind the ability to flow much better at cold temperatures and extended oil change intervals...All mobil 1 does that normal, on sale, oil don't do is to lubricate at heat temps that our engines don't get up to. (above 400*F)
So if we can never use it's ONLY potential...why spend the bucks?
Advertising at it's best is why.
