When you go mudding in your truck, do you wear a helmet?
Do you wear a helmet when mudding in your truck?
  • Total voters
    33
  • Poll closed .
OilPatch197
Pros and Cons...
I pretty much wear a bicycle helmet with stickers on it every where I go...so yeah.
i see no need for a helmet unless youre doing serious rock crawling, or something like that.
it depends on how apparent the risk of whatever were doing is. ive spent a whole day taking turns jumping a ranger with broken out windows and yes, i wore a helmet because it made the event "feel safer", even though it eventually did roll over and make a huge steam show (popped off the radiator hoses when the body mounts and steering shaft failed). ive also been mud bogging in a jeep without a helmet, but didnt feel unsafe (maybe it was the roll cage that inspired confidence?)
No, I live in Redneck Central we don't were brain buckets around here, we just but your brain in a bucket after the wreck.
Many of the old Die hard mud trucks never came equipped with seat belts. I have a co-worker with a scout, has no seat belts, and he does not wear a helmet.
only if the place im mudding requires it, some of the bigger competions require one, but otherwise no.
I just splash for the most part. There has never been any danger of me hitting my head from getting jolted around so i never worry about it. I bump my head from time to time but not nearly hard enough to do anything. I will wear a helmet when It is required or I know I am going to be beatin around.
Pros - head is safe when getting jolted around and keeps you from knocking your self out behind the wheel if you hit your head.
Cons - If you get in a serious wreck you could break a few more bones like the collar bones even your neck!, And limited vision (I can't stand helmets cause I have to physically turn my head to look around and then I'm not looking ahead.)
healmet?? im from texas, i dont even wear a shirt when i go muddin:icon_twisted:
the only time i ever wore a helmet was when i was in a mud bog/drag that required a helmet. other than that....Never.
