- Apr 18, 2008
- Age
- 88
- Austin
Nope! Nope! Nope!!
What some here need is a little SPARK 101! What the hell difference does the plug gap make?
Well I'll tell ya.. Back in the carb days the plug gap was .030 or thereabouts.. Then we started using injection.. Now we have improved injection.. What difference does this make to the plug gap? (you should ask yourself).. But you didn't so I will tell you.
The carbed engines had an overly RICH mixture, got bad milage. The plugs were gapped at the .030 because there was always enough rich fuel in that small gap to start the fire when the spark occured.
Then the early fuelies came around and it was found that the engine sometimes missed...because there wasn't enough lean fuel in the .030 gap to start the fire. So the gap was increased to .044 to make sure there was ALWAYS enough fuel to start the fire.
Nowadays with the even smarter computers the mixture is even LEANER and many vehicles require the .055 gap to have enough fuel..consistantly.. in the gap to start the fire.
Each of these improvements in fuel economy required a slightly stronger coil..
So Now, if you can read, you see WHY the gap has been changed. It is all about starting the fire, with the newer leaner fuel, in the chamber and economy.
Now if your present coil and gap is consistantly lighting the mixture, there is no reason to swap to something else. Once lit the fire is the same fire, nothing can change that! NOTHING can improve the fire!
There can be NO GAIN form ANY coil or plug or plug gap, if what you have now is running smoothly.
The worlds greatest, most highly advertised coil, will NOT improve on a good running engine.. IT IS IMPOSSIBLE!
No matter what the driveway cowboys tell ya.. It simply cannot happen.
Also a wider gap will not do one damn thing.. If your factory gap is running smoothly.. wider ain't better!
And NO! Thinking the different coil did something for your ride ain't true! It is a "pride of possession" thing. Guys are slow to admit they have been TAKEN by the advertisements.. They seldom admit that nothing has happened since they spent the dollars to get a so-called "improvement" to their rides.
Big Jim
The increased plug gap is the key here; that's what gives
better performance. And a higher voltage/joules rated coil
will fire a wider gap, so it's true that a performance coil
combined with wider gaped plugs will give more performance.
In thumbing thru some 3.0 specs, I see the plug gap spec for pre-06's
is .044", and the gap for post 06's is .055". That tells me Ford
has a better coil for the later models (possibly COP?)......
Big Jim
