- Jul 17, 2009
I have another thread going on a running problem but hadn't mentioned a symptom because I had been told by a mechanic that it was a normal condition so I wanted to post a new thread for this.
Starting the vehicle cold the IAC does alot of correcting.The idle goes from low to high a number of times before it settles at an even 800rpm.A friend said this wasn't normal and suggested this might be a vac leak.
I've been thru the vac system and can find no leaks.Has anyone had any experience with such a problem?Any suggestions?
The running problem is rough idle and hesitation throughout the rpm range especially noticeable from 1500-3000rpm.at rpm's lower and higher than this it is not nearly as much but is still perceptible.At higher speeds it's hard to tell.
Thanks
Thanks
