help
PaleBlue90
Boosted (Not Stock)
Aurora Colorado
so my 93 exploder had a stock tape deck, so i go to install my cd deck. i have power, and all my wires are in the same spot as my 92 expoder sport. BUT i have no sound? wtf? anyone have a wireing diagram?
so i just went out and tested the front and rear speaker wires on my cd deck to see if there working, they do. i hooked them up to a speaker directly. it works. try and go through the trucks radio harness and no sound
Maybe this will help you. You might have the factory Premium sound option which can complicate things a little bit.
  • help
thanks,
my wires dont match the diagram though.
my wires are
red-power
yellow-power
black-ground
purple-rear speakers
purple with a black stripe-rear speakers
green-front speakers
green with a white stripe-front speakers
grey -idk
grey with a black strip -idk
soild blue -it gos to nothing
blue with a white stripe- my amp power supply
and orange-accessory
:icon_confused:
thanks,
my wires are
red-power
yellow-power
black-ground
grey -idk
:icon_confused:
Thats just F-ed up...?:icon_confused:
All cd players should have
Purple - RR Power
Prpl/Bl - RR Ground
Green - LR Power
Grn/Bl - LR Ground
White - LF Power
Wht/Bl - LF ground
Grey - RF Power
Gry/Bl - RF ground
Red - Switched 12v
Yellow - Constant 12V
Black - Chassis Ground
Blue - Power antenna/Romote
Orange - Illumination
Orng/Wht - Dimmer
Or atleast all of my players are set up like that.
Edit: Does the spolder have a factory premium system which could have an amp? (cause if it did then the new player might not feed the amp?)
no mine didnt have the amp. it had a tape deck
heres what my tape deck looked like
help
Your radio is the premium sound radio, it DOES have an AMP.
And an aftermarket head unit won't turn the amp on
and would grotesquely over-drive it if it was turned on.
there is an aftermarket harness that replaces the amp
it's a little short cable with two female connectors
that essentially jumpers past the amp.
The amp is mounted below the passenger side quarter window above the wheel well
you have to remove the interior panel to get at it.
AD
Allan D is the man... it amazes me how much s**t he knows about these trucks!
AD
yea i saw that you posted that while i was at school so at lunch i got her all wired up. i wired the whole truck in 35 mins:D
yea no sh*t lol he amazes me with the things he knows:icon_thumby:
have a cold one on me allan D:beer:
