- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
I know it isn't the cleanest install, especially all of the oil on the thing! but you know how bad the PCV system is, and also how valve cover bolts work loose or at least the seal needing to seat... the oil drenching isn't as bad as it once was, don't know why but I'm going with it...
from the pics you can see my nifty DIY intake elbow made of drier tubing and blue duct tape (blue makes it faster), and my fancy DIS module heat sink, the rest is pretty straight forward. You can also notice that I put in the extreme duty 4.0 explorer radiator, I went with it's schroud even though it's a good 3 inches larger diameter than my fan, but my stock schroud is more of a safety shield to keep your fingers out of the fan than an actual schroud, so I figured this would work better.
thought I'd share since it's been a solid 7 months since I got it running... in my defence I mispaced my camera for a few of those months in the middle
