MAF help...
Kachess
Ellensburg, Wa
My Mass Airflow Sensor is out on my 95 4.0 so I was looking at what to get. I found and Granatelli Racing one that says 10 to 15hp increase for $340. Sounded hard to believe, is this legitimate or should i just buy an OEM replacement? Any input is great, thanks.
Get the OEm.
the factory one is NOT a restriction.
Would you believe them if they said using their air meter would get you laid?
AD
i hear you only really need that stuff if you use a supercharger.
As usual, the same aftermarket hype! Stay with the OEM MAF sensor!
