- Feb 10, 2009
- Age
- 35
- Sanford, NC
I wans't sure where to stick this so mods please move it where you see fit.
While installing my new Bilsteins I found a hairline crack by the drivers side upper shock mount. It's been about a week and half since i've discovered it and it appears to me that it has gotten worse. Before I throw more money into this thing i'd like some professional opinions as to what I should do. I hate to be out on the road and put others in danger or be on a trail and my frame just snaps in half. It hasn't cracked all the way up the side of the frame but it starts at the bottom and is getting progessively worse going up. How could I repair this, if at all? Here's two pictures. When I get it on a lift I will take some better pictures but that may be awhile. It only goes up the "O" in the frame you can see in the second picture and it's not visible when looking on the other side of the frame. The only thing you can see from the other side is the crack where the frame has actually split at.
The truck is only a 99 but I have replaced a section of the rear frame before and some chunks of the crossmembers have rusted out. The cross member across the gas tank is also rusted through pretty good on the passenger side where it's attached to the frame.
