New gauges
warrior24
Surprise, AZ
Here is what I put together to be able to monitor the oil pressure volts and water temp as we all know the factory ones are just dummy ones. I bought this kit at autozone I think it was like 27 bucks. It came with the front metal stamped faceplate I just added the outside piece made out of stainless steel I had lying around and used an old heavy duty paper cutter I had to cut the steel and bent it to shape. Then I used epoxy to glue it to the front face plate. Once it was nice and dry I sanded it and primed then painted. I just need to hook up the voltmeter I have it temporally hooked up to make sure it works which is why you can see the wires hanging. Any place special I should hook the voltmeter up to? I would also like to change the color of the lights to match the factory green ones.
Excuse the dustiness its Arizona:headbang:
  • New gauges
  • New gauges
  • New gauges
1.5" gauges. So what do you guys think any comments are welcome. Does it look good, ugly or look like a big steaming pile of horse crap.
looks nice but u need to hide those wires, looks neat, shame the needles arent white, so it would match the cluster ones...
