- Jul 23, 2009
So, it looks like the pinion seal from at the rear diff is leaking. This is a 1999 2.5L with the 7.5" rear end. I've searched on here and some people seem to say it's not that bad while others say it is one that's prone to error. Can someone point me to a walk-through on this job, if it exists, or let me know the critical points where I could make an error? I read about problems with the pinion nut (not sure where that is...oh boy) not being torqued correctly, but someone else had quoted 180 ft-lbs and red loctite when reinstalling. Also, someone had cautioned about not damaging the pinion bearing when removing the seal. So far, here is how I think it goes:
Remove rear diff cover and drain fluid. Unbolt "crossbolt" that holds the pinion in (not sure which that is, but it should be apparent, I think). Slide the pinion back partially out of the diff. Remove pinion seal with a "hook-type" seal puller (any more details on that?). Install new seal and reverse the process.
Not sure where the pinion nut comes into play in this or what its function is. I'd like to get it lined up as much as possible in my mind before I try this job, so any details would be appreciated.
Thanks,
-Rob
Thanks,
-Rob
