- Jul 17, 2009
I've got a running problem with this 87 Ranger.The engine surges or hesitates at idle and when I get it on the road it runs fairly smooth up till 2000 rpm,at which point it starts bucking.For lack of a better description it is more like a soft bucking... I have a lifter ticking.Adjusted the valves per manual instructions 1 1/2 turns down.Still ticking.Could this lifter be causing my problem? If so I can't identify it's location from outside.When I disassemble the top end how can I check the lifters to determine the bad one.
Any other suggestions for things to do or check at this point would be appreciated.Thanks
