I have a 94 ranger,2 wd,5 speed manual. A while back my truck was acting a little funny while driving.If I was at normal driving speeds and tried to give it gas to pass someone it would rev up for a second or two before actually going faster.Then the problem got worse and was doing it all the time.I eventualy parked it for a while till I could figure it out.Today I bleed the Hydrualic in hopes that would help.Sadly it did not.I bleed the system untill all the air bubbles stopped.I even bleed it a little more just to make sure.The truck still shifts fine and drives but,it seems like the clutch isn't letting go fully.I have even read about testing to see if the clutch was bad by parking the truck against an imovable object and putting it in 5th gear and release the clutch.I did and it stalled immediately.From what I read that meant the clutch was still good.What about the clutch cable,does this need adjusting or is it a self-adjusting cable?I am hoping this is something I can fix myself as I don't have the money to take it in somewhere.Any help would be greatly appreciated.If anymore info is needed let me know,I will be checking back often cause I only have till Monday to get it running again and get the tags renewed before it is towed away.Procrastination is a pain I know.Thanks again!
