- Jun 29, 2009
- St.Louis Mo
Well, I'm saddened and pissed today. My rear ends been acting funny sense I got my truck from the dealer. They said it was just the way it was ( coughbullshitcough). Also as of late it's been slipping in and out of gear radomly and my brakes have felt a little lose.
I was driving today and was about 6 car lengths away from a braking car going 35. I went to brake and felt the truck trying to stop but couldn't in time and have to swirve to miss them.Lucky me, I was next to my friends auto shop and pulled in immediately.He put the truck up and went to remove the drums and couldn't. He had to beat them off with a small sledge hammer. The moment he removed the drum ( happened on both side mind you )hing but rust came pouring out. When he cleared the dust, it was any ones worst nightmare. These drum brakes and hardware were so rusted,that he had to heat up the adjusters to remove them because they were coated in rust and he said they have been for well over a yr or so.
He put new adjusters on just so I could get home and have brakes and get it to the dealer. The brakes stop working good pretty fast too. He also started viewing the rear end after he test drove because he felt the shifting in the back end I've been feeling and the dealership said was normal. He put it back up and measured from the center of the hubs on the passenger side and it was at 125 1/2 inches. He then measured the driver side and it was at 127 1/4 inches. His 9 yr old son pointed out the passenger side tire was sticking out.Indeed it was by over an inch and the driver side was receded by the same. He spend 2 hours on the truck checking EVERYTHING.
After 2 hours or so he noticed the leaf springs were flat ( no normal arch ) and that they were all warped up really bad. It was causing the rear axle to move all over the place while driving. He noted and pointed out to me that the axle was were it was supposed to be in relations to the factory mounting to the leaf springs and that the retaining bolt that keeps it from moving on the leaf was solid and intact. He did how ever state the U bolts were now warped and that with the leaf springs warping and bending all over Gods green earth that it was a matter of time before something had to give because of all the stress and torque bending to the leafs,shocks and other components.
I went to the dealer immediately and have the rusted shut adjusters in hand, bill for the repair and all the info I seen and was told. Needless to say I called them out on their " QUALITY ASSURANCE AND SAFETY CHECKS THEY DO BEFORE SELLING ANY CAR OR TRUCK ". They gave me that BS smile and called their shop and their shop told them my truck wasn't safe to drive and to bring it in right that second. The shop managers jaw dropped when I showed him the adjusters and all the info.
Now, the key is are they going to try and BS me some more and not make the repairs? Odds are, probably. I have that covered. I have the safety inspection from them and will turn it and all info I received from my mechanic ready to turn over to the State police ( They help in force and regulate safety inspections ) ( it should not of passed with non functional rear brakes and a bad rear end that travels every where, safety hazzard )and my wife is second in charge of a local charity ( national as well ) and they have many connections in radio and local TV media that I will tap in to! I'll also file a complaint with the BBB ( they are a member ) and the State Att. General !
I'll keep you up dated!
