Spindle lift?
  • Thread starter Thread starter irishblessing
  • Start date Start date
irishblessing
Guest
ive been wanting to lift my truck for a while im tired of the stock sitting of the truck (rear end sits higher) so i just want to level it out i bouth longer springs it brought it up a little but higher but not enought to level it out so i ws thinking about buying a spindle lift has anybody done this or know how much a good set would cost me or any cheaper ideas would be appreciated
I don't think you can get a spindle lift for your 96, maybe someone can prove me wrong?
+1 I've only seen spindle lifts for the 98-up IFS Rangers.. Check out the Tech Section under Leveling Kits and Lifting for Cheap, in addition to the longer coils you have you could basically go with a coil spacer or F150 perches (works like a coil spacer).
^^yeah i dont want to completely screw up my alignment its of already how would i correct that after
There's actually a thread HERE with a lot of info, and a link to a tech video that helps show you everything we're talking about. There's also part numbers for everything, including the adjustable bushings you'll need to fully correct your alignment afterwards.
^^ it looks like i got about the same lift as you from my springs but im looking to get it level thanks for the info
