- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
I'm getting codes 51 and 67, looking it up 51 was coolant temp open or high and 67 was neutral switch open or something (I don't have a neutral switch)
'86 2.3T out of a T bird, PC1 computer running DIS with just passenger side plugs
what it's doing is spitting, sputtering, surging, backfiring and not running to it's normal self. I had a crank sensor issue (well mostly a crank pulley issue) which was fixed, but it was missfiring a lot right before I fixed it. I know missfiring can cause catalyst failures, which has been on my mind since this has been having issues after I fixed the crank pulley. I have a boost gage and it does get to 10psi like it used to, but it seems like I have about half the power it used to have.
I found my compression tester today, so in the near future I will be doing a compression test, I know the valves leak since it took a lot of air when I changed the valve seals...
I went to the junk yard today and grabbed another ignition module, changed it and it ran the same so either the new module has the same issue or it wasn't the problem. I also swapped the coil pack and it ran the same, so I pretty much eliminated the ignition system, although I havent checked the spark plugs but they only have about 6K on them.
when I relocated the O2 sensor I didn't look where I put it close enough and the wires could have contacted the frame and shorted, and it just adjusted the fueling too far out I'll reset the computer and see how that goes.
I'm leaning twards the cat myself, I've been needing to redo the exhaust so I guess it's just time, I believe I can get the components (muffler and cat) for around $50 through work, do the Thrush welded mufflers work good on the 2.3T?
Thanks for any assistance.
