Can I Do It With No Problems
SCRAPINRANGER302
I will be moving to Va in the next year from De. I'm trying to see if my ranger will be up to the task. My ranger is a 98 xlt x-cab 2wd auto. I have no clue how to tell if I have the towing package. I need to be able to tow 87 gti 16v racer to Va with me. A 2wheel dolly is out of the question. I'm planning on purchasing an aluminum open car trailer because its lighter. My vw weighs less then 2000lbs. I believe the trailer I'm looking at weighs 1800lbs. Currently The truck has a bumper mount. I'm getting rid of that and would like to get the best hitch for my truck. I'm planning on installing a trans temp guage. My truck already has a factory trans cooler. Will my truck be able to make this trip with no issues? What else should Ipurchase for this trip? Will I have to stop at weigh stations along the way? I always wondered about that one. Thank you in advance
what motor and rear gear ratio? if it has the 4.0 and 3.73's it should be capable. you will want trailer brakes! dont worry about weigh stations, their only concerned with commercial carriers. why would a 2 wheel dolly be out of the question? it would be cheaper than a alumminum trailer. definetly get a reiceiver hitch. you may want a load-distributing hitch head with sway bars as well.
I'm under the impression the towed vehicle in question is more like a race car. The rear suspension/tires may not care for long periods of crappy highway.
I towed my dad's Ion on a open car trailer with my Red Ranger (see sig). Not something I would do for any real distance, and you can forget about highway speeds with a 2.3L. That trailer is certainly not lighter than a Dolly.
x2 on the what engine you have and what ratio. As long as you get a good hitch (Reese, Valley, Etc.) and a ball with as thick a shaft as you can get you should be good on that end. I've been tickled pink with my Reese hitch.
I towed my 3200lb drag car on a 16ft open car trailor.... through central Ky to home over some pretty steeep grades with a 5spd, 2.3 liter 2wd short bed step-side (on a bumper hitch, oh yeah) with no trailor brakes. It wouldn't get out of 3rd gear going up the hills though, and you needed about 2 miles to stop.
Honestly the only concern I have for you is the trans.
Frank
I planned on getting as big as a hitch as I could. I would feel much safer with a full trailer. The truck has a 3.0 engine and 3.73 rear gears. I planned on getting one of those load leveling kits along with the air lift helper springs. What concerns about the trans do you have Frank? Is it something I can do to take care of a potential issue? Thanks for all the input. I dont want to have to get my dads jeep limited to tow my car all the way down. I would rather put the money into my truck so I will have a capable light tow vehicle after my move. Once I get down there my v8 swap will happen. My state wont let me do it legally now.
Ive towed (with my 88 auto in sig) it wound up crapping out, Ford's auto's are throw away transmissions IMO.
Frank
The automatic in your truck is much better than the A4LD that blesses Frank's Ranger... and mine.
Why is a 2 wheel dolly out of the question? The GTI is FWD, right?
The 2 wheel dolly is out of the question because of how very low it is. The car has $2,400 worth of coilovers on it and is set very firm. It has taken me almost 1 1/2 years to get it set up right where I like it and I don't want to go through the hassle of adjusting then readjusting then adjusting some more and then adjusting and readjusting some more. The full trailer will work better for me in the long run. I have other vehicles and projects I would like to be able to tow. I just cant see wasting the money on a 2 wheel dolly when I would prefer the full size. I realize the ranger is very small to be a for real tow rig. I dont want it to be a tow rig I would just like to be able to use it when I need it. What other things should I be concearned about with my trip?Thanks again everybody for the input.
You can use a much smaller trailer for that car. I would get a 6'x12' or 6x14'--not knowing how long the GTI is--single axle utility trailer with a 3,500# axle on it and a drop gate like they use for lawn equipment. That VW would be just fine on it and it's more within the ability of your Ranger. These weigh about 1,000# soaking wet. Brakes are cheap and easy to add if it doesn't have them. And it would be very useful around the house when you get it. Much better for daily life than an 1,800# car hauler.
The vw is small. Physically I think it would fit on there I would just be concerned about the integrity of the trailer. Do you think that I could actually do that with no problems? I'm curious about this one. Thank you
Actially I think it would. Maybe add some extra bracing under where the wheels would sit (just in case). If the trailer is built related to what the axle can carry then definitely (3500 lb axle, 1000lbs of trailer, supporting 2,500lbs). Those style trailers pictured are everywhere, alot of which commercially produced, and of fairly basic ,proven, and documented design. Just double check the weight capacity on them to make sure.
In addition to the extra bracing, there is weight distribution. It's a little trickier on a single axled trailer, but not bad. You can easily fine tune the wheel placement backwards or forward to keep roughly 600lbs tongue weight (If you end up using it that much to justify moving the axle), along with a weight distributing hitch if nessecary (Or just the distributing hitch itself).
Being that it's a lightweight racecar and not a 3000-4000lb or more loaded sedan makes your options much broader.
1x8's crossways with plywood over them will brace it enough to not punch through as well.
Frank
It's got 2-by decking on it. It will have no trouble with that car.
These trailers do seem flimsy. But they work. Making sure you have tongue weight is the main issue--as was stated.
One problem about having sides on a trailer you haul a car with, is it makes it tough to get out of the car once you have it loaded.
That short of a deck won't leave you much room to move the thing around to get the balance right. They are made for lawn mowers and four wheelers, not cars.
I think by the time you get one of those, dink around getting brakes on it, I vote you would be better off to get a trailer that is actually made for hauling cars. You can get a nice used car trailer for about what those single axle trailers cost new.
It sounds like you have other things to haul (it doesn't take much to get something bigger thana VW), and maybe other things to pull the trailer with (??) so I would get as big as you are going to need it rather than just big enough to squeek by with.
Or you could check out a rental too.
