A4LD to FM145 swap
Chevelle Kid
Long Island
Ok, I'm swapping my A4LD for an FM145. I want to know what exactly I need to do to complete this swap. I was reading the tech articles and came across this...
Replacing an A4LD Automatic with a 2.8 Manual Transmission:
A transmission that came off a 2.8L will work on a 2.9L. The 2.9L flywheel and starter will bolt up and work perfectly. The 2.8L clutch disc and pressure plate bolt perfectly to the 2.9L flywheel. This means that the 2.8L, 2.9L, and 4.0L all use the same clutch internals.
The only downside to swapping in an early Mitsubishi for an A4LD is that you need the tranny cross member that bolts INSIDE the frame. On the Mitsubishi's there is no t-case adapter as it is built into the tranny. This causes the tranny cross member to be moved 2.5" toward the motor and you need to lengthen the rear driveshaft and shorten the front one.
Is this true? I have the shafts out of both vehicles and both seemed to be the same length, I held them alongside each other.
So, any help is apprecieated...lol
Ben
absolutely correct. when replacing n a4ld with an fm145, you will need to move the transmission cross member. there should be holes in the frame to put the cross member where it needs to go. you'll also have to use the shorter front shaft and the longer rear shaft.
i've done this swap btw. it only lasted like 10k miles before i swapped out the junk mitsu trans for a mazda trans. the mazda trans is the same length as the automatic though, so you need the drive shafts from the auto if you switch to a mazda trans.
Well I have this trans now...lol I'll probabally pick up a M50D within the next year or so...lol
I also plan on doing the 4.0 clutch swap too
Ben
Ben
+1 You won't be sorry you did either of these upgrades. I'd go directly to the Mazda trans now if funds allowed.:icon_thumby:
Ben
make sure you hang on to your old drive shafts. you'll need them when you switch to a mazda trans. sounds like youre gonna do exactly what i did.
Probably...lol I have the 4.0 clutch stuff now, I just need to get the trans and pedal assy. from the other truck. I have it 99.9999999% out except for the damn clutch pedal. How do I get the freaking clip off of the pedal from the rod that goes into the slave cylinder on the firewall?????
Ben
Ben
very very carefully... and you'll still probably break it like i did. i've broken every one i've touched. last i knew they were still available from ford though, like $6-8 iirc. oh and even if you break one or 2 barbs off of it, it will still probably work. i've used them like that before. :dunno:
