- Aug 16, 2007
- Age
- 56
- Edmonton,AB
- 4.0 V6
Suppose to be 10 IN / LBS not Ft/LBSAlso took the trans (A4LD) out of my truck and found the overdrive band burnt. (again) but the frictions and steels still with the printing still on it. When I adjusted the overdrive band, I torqued to 10foot pounds, then backed out 1 1/2 turns. Still too tight? No other damage found in the trans out of the pickup.
Any tips to keep the over drive band from burning again? Am I not adjusting it correctly? Could I have a valve on the valve body leaking or a bad servo?
What does the surface of the coast clutch drum look like ? Put a straight edge to it to make sure it's flat. Check the rubber seal of servo piston . Should be nice and soft. If not or in doubt , change it.
