- Oct 19, 2008
- Regina,Saskatchewan
Me in the stickies doing conversions on 4x4's ? Got me mixed up with someone else.
http://therangerstation.com/forums/showthread.php?t=244
"1st truck setup:
87\" standard cab longbed 2\" body lift, stock suspention
87' 351W mildy built (10.5:1comp, ported heads, 4x4 cam, ~275 hp)
made my own pan by cutting sump off of a truck pan and welding on a kick out. thought of going dry sump, have the parts but havent done it yet.
headers custom made, 15/8\" pri to 3\" fenderwell exit, side piped
adapted a 70's saginaw 4spd to truck bellhousing using 11\" clutch and hydralic
slave
Using a divorced dana 24 transfer case
7.5 rear/d28 front from diesel w/larger yoke
motor mounts from 79' lincon
radiator from 96 ford club van
650 double pumper
stock gas tank, added efi fuel pump and regulator
28k miles on this setup, only problem was oil pump gave out on my on freeway
2nd truck setup:
87\" standard cab longbed 2\" body lift, 3\" suspention lift
86' 351W stroked to 396ci full race build (12.5:1 victor jr. ported and polished, race cam, main girdle, h beam rods, forged crank ~575hp)
headers custom made, 13/4\" pri to 3\" fenderwell exit, side piped
adapted a built T5 to truck bellhousing using 12\" clutch and hydralic
slave
8.8 rear posi/d28 front locked w/larger yoke
radiator from 98 ford club van
850 double pumper
aluminum race cell mounted behind axle w/ efi fuel pump and regulator
10k miles on it before i realized that i was retarded putting that kind of engine in a 4x4, going to pull it in favor of a 306ci
3rd truck setup:
87\" standard cab (i must like 87's!) 2\" body lift, currently no suspention lift
(looking at a d60 front / d60 rear later)
82' 306ci mild build(10:1 gt40 heads, mild cam and EFI ~225hp)
made my own pan by cutting sump off of a truck pan and welding on a kick out. (i thought if it works so well, why change! plus I have the patteren all drawn out..)
stock f150 exaust manifolds to 2\"
T18 bolted to a 205
8.8 rear tracloc(need d60 w/detroit!)/ d28 front locked soon to be replaced with d60
motor mounts from 80' lincon
radiator from 95 ford club van
EFI
rear gas tank from B2
truck has not left my garage yet (still playing with the EFI)
If I could say anything about these three trucks, its LIFT THE BODY!!! it is so much easier to do these kind of conversions when you have an extra 2 - 3 inches to work with under there. Also dont screw around with using tiny radiators. throw the biggest one in that will fit in the frame. You will be glad you did when you get 20 miles from no where on a 115 degree day
thx,
john
from bad 457?
ok well if this aint you i dunno who it is! haha i assumed you cut the "dad"
