3.0 to 4.0 swap
swickwake
Porterville or Chico Ca
i am planing to do a 3.0 to 4.0 swap in to me 98 ranger. will me dash harness out of my 3.0 work. would i have to change some thing to make the 4.0 work.
thanks for the help
shane
For a plug and play swap you need to swap out the entire engine compartment harness from the 4.0 donor vehicle. This harness will plug into the bulkhead and work with the interior/dash wiring.
i thought i read some where that the 3.0 and 4.0 trannys are different and wont bolt up?
You will need a new computer and tranny to go with all that other stuff.
the vehicle wiring is the same.. your going to need the motor, tranny tranny wiring harness, COMPUTER , Maf sensor, and engine wiring.. an everything should plug right in.. i just put a 4.0 from a 92 explorer in my 96 which had a 2.3 an got it all obd II compliant an it runs GREAT!!
what of the speedo cluster
the cluster i have has no tach
do i need to find a cluster with a tach to make this swap work?
u dont necessarily need a tach but there nice to have, u can just listen to the engine revs and know when to shift, or u can buy a tach from autozone
You meant plug and PRAY, didn't you?
hey guys,i have a friend who has a 351 winsor ,is it possible to put it in my 96 ranger"?
