- Sep 23, 2007
- Age
- 97
Any tips?
Right now I am evaluating the engine bay and I see like eight or nine of those wire taps(the kind that cuts thru the insulation) and I would like to rewire this "beast". (it looks like they basically "bypassed the bad wiring with new wiring, so I got like a dozen wires I don't need)
What is the best connectors I can use to create a "Y" and union joints?
My plan was to use some crimp rings, they are tubes you put the wire in and crimp and I was planning on using heat shrink tubing over that.
I also thought about using spade terminals that has the clear heat shrink tubing already on the connector.
Any suggestions on the best method to mate wires and seal them to protect from moisture?
I see someone used some wire nuts and electrical tape abounds, those cheap wire taps, and a few of those "no crimp" reusable twist locks.
These are all out, no protectiong what-so-ever.
Also any advice on how to clean the connectors for the various sensors? I would like to remove some oxidation from the exposed wire so I can crimp or solder new wire, I thought about soaking the connector in White vinigar(cleans pennies) your thoughts on this?
