- Sep 6, 2008
- Age
- 36
- dirty jersey
- 06 chevy
heres the problem....in the morning if i start the truck(cant cause im replacing plugs and wires with no help from the bees) but then turn it off after running and driving it a bit it will not restart even if i use ether. im replacing the fuel filter once i find it and then kill the wasps. it started doing this after i burnt up the ignition wire last year then when my friend fixed it, it started on the first try(go figure) and worked fine for a few weeks, then it started acting up. it has a new battery, no exhaust, bad front tank fuel pump(rear tank works fine) and more chewed wires than i know what to do with(like that when i got it).
