I'm looking for a B2 and plan on doing the 4.0 swap. I know the 89 and 90 are easier swaps but how much more difficult is the swap in the "1st gen" B2?
Thanks for reading my first post!
I've never seen a B2 factory with an M5OD...Most '90 models with a manual have the M5OD![]()
Only if it's an 84 or 85...you have to change a few things with the fuel system carb to efi
If it is a '90 Bronco II and has a transmission code of "M", then it has the M50D. It was an option to the FM-146 in '90. The 1-4 gear ratios were lower than the 4.0 M50D.I've never seen a B2 factory with an M5OD..
