- Feb 14, 2009
- Boise, IDAHO
2003 Ranger FX4 - all stock - 4wd.
Couple months ago, I changed the pads and rotors on the front axle since the pads were about worn out and the rotors couldn't be machined. After changing them, I had a terrible squeal when applying the brakes (I can't remember if I was getting a squeal before I changed them or not). I figured that it was dirt or something between the pads and rotors, so I took them off a couple times and cleaned everything with brake cleaner. Still squeals.
I was going to buy some new pads, but when I told the guy at the parts store, he thought it might be the calipers. He was thinking that maybe there was some vibrations in there that caused the squeal. I put some brake grease on the backs of the pads and that seemed to help a little bit for awhile, but it got just as bad again.
This weekend, I finally got tired of the squealing and sprung for the calipers. I got finished installing them and took it out for a spin. It seems to stop better now, but I still have a squeal. Doesn't seem to do it until the brakes heat up. First couple stops, it doesn't squeal, but after that, it just gets plain embarrassing - not to mention how torqued off I am at having just spent that $$ for nothing!
The squeal occurs when you put a little bit of pressure on the brakes or a lot and everywhere in between. I didn't get the best brake pads when I got them, but then again, I didn't get the cheapest, either. I'm once again thinking on springing for new pads or else just taking it into a shop because I'm getting tired of messing with it.
Has anybody else had this issue or have any ideas?
Thanks for your help!
Doug
Doug
If new pads don't fix it this time, its going into the shop.
