- Mar 7, 2009
Hey Fatboy! That's a good idea. However, I've tried the spare key which has almost never been used and the truck behaves the same way. If the regular key was damaged in some way that would cause the security system to lock out the ignition, you would think the spare key would allow the truck to start. But it doesn't seem to matter which key is used, the ignition system still would not fire up.
Today I spent some time checking sensor signals plus power and grounds at the PCM header connector. Everything checks out but the truck still would not run. So, I pulled the PCM out to have a look see and as luck would have it the unit has removable covers. Inside there were three easily identifiable FET's all clustered together so those had to be for the ignition coils. For yuks, I traced the path from the header pins back to the FET's. No problems found. I spent a good half hour going over the PC board with a lab type lighted magnifier looking for any possible sign of a cold solder joint. It all looks good. So then I reinstalled the PCM with the top cover off and then powered it up by turning on the ignition. There were several surface mount type voltage regulators that would be easy to check with the DVM so I poked around and found a lot of 5 volt regulators, all doing their thing. Sigh......
So, just for yuks, I jump into the drivers seat and give it another try. Engine started right up and ran perfectly.
I'm going to check with the Ford dealer and see if they have the means to test a stand alone PCM. Just to rule it out....
Back to Fatboy's point about the pats key, maybe the key isn't the problem but the device that reads the key???
Does anyone know how exactly the truck is suppose to behave if someone tries to start the engine with a bogus key? Does it just cut out the ignition system, like what I’m seeing? I would have guessed that the engine would not even turn over if someone tried to use a bad key.
Sorry for the windy write up....
