- Oct 21, 2008
bad idea? 87 Bronco II dana 28 with manual hubs. Should I quit being a cheap ass and buy a locker?
i dont know if i would do that. probably make it harder to turn and even harder on your tires
The ONLY way it would make it harder to turn on the street is if the MANUAL hubs were locked in.probably make it harder to turn and even harder on your tires
Nope, the ONLY way it would be a problem on the street is if the manual hubs are locked in. Re-read the OP's question and then re-read my response.You're joking, right?
Exactly.i think what lil_blue_ford was saying was, why lock a d28? it won't last. They barely survive with stock tires and an open diff. Much less M/T's and a locker.
Have you ever welded a D-28 and ran it? Probably not.... a D-30 will take way more abuse than a D-28 ever will.Don't listen to these guys. Weld it. You will be ok, I build crawlers for a living. Everything gets welded, just make sure the ring and the pinion gear are good and clean before you weld them.
Heh, 3wd is a good way to get stuck... when I blew my front shaft I had to get my buddy with a YJ on 34" LTB's to yank me out cuz I was buried pretty much to the frame and I got there in one big hurry when there was a loud bang in the front end from that axle snapping.I have no problem with welding a differential. But welding a differential that is weak enough to blow shafts when its OPEN is just asking for trouble by welding it. And if you think 1 axle shaft blows, your ok because you got 3wd still, good luck. If you broke 1 axle while both front wheels are pulling, your going to break the other twice as fast when its doing all the work. I'd suggest swapping in a D35 and welding it, if you actually going to use the truck.
