I had the same problem, and went through the same steps you did. When I closed the hood the rough idle would get worse. Turns out it was the clamp/grommet on the end of the air intake tube coming out of the MAF. The grommet wasn't slid over the plastic tube enough and when I tightened the clamp it created a gap that allowed air in. It was underneath so I could not see it happening. I thought about checking it after a trip to a u-pull-it salvage yard and running across a similar issue there.
I had the same problem. The end of the air tube fits inside of a groove in the grommet, but wasn't in there. The entire grommet was just over the end of the tube. Either it was that way from the factory or something I did in the past, I have had that off before. The air tube was distorted from being connected like that, so I hit it with a heat gun and molded it back into shape. With the grommet on correctly the leak is sealed and the occasional stumble I had seems to be gone.
One note on the stumble- it seemed to occur more when making a sharp right turn. I think the engine was shifting slightly from the centrifugal force and was opening the gap in the improperly fitted air duct.
