- Nov 7, 2007
- Age
- 39
- elk mound, wis
all i want for my explorer is a minor 2.5-4 inch lift, pretty much i want it to handle better and be just a little bit taller, it already has some fairly agressive tires on it, i just want it taller for better ground clearance and keep the tires that it has, what would be a good lift system for this? the rear leaves are worn out so they need to be replaced, unsure if i want to put the axle under the springs, dont want it too high because i want to keep the tires i got on it and not suffer the fuel milage decrease of bigger tires.
what should i go with?
