Here's my recent experience... When I deleted the brake booster in favor of manual brakes I had to remove a master cylinder firewall plate from another Ranger so I could re-mount the master on the firewall without the booster. The brake pedal lever for power brakes is different in the location of the stud from the fulcrum since less leverage is required.
The problem with converting to a manual setup is that the master mounts higher and requires the stud for the brake rod to be closer to the fulcrum for increased leverage as well as proper angle approaching the master cylinder piston.
Removing the brake pedal lever is no picnic on manual trans models since you have to extract the clutch pedal lever. If you've ever done this you know what I mean.
The clutch pedal lever has a long shaft welded to it that slides through the support and brake lever pivot and is kept in place by a circlip on the right side of the support.
In order to gain enough room to the left of the support to clear the length of the long shaft I had to move the main harness out of the way which meant unbolting the round multipin firewall connector from under the hood and separating the halves.
The inner half is held in the firewall by 3 pressure clips and once released allowed enough slack to pull the harness out of my way. When I thought I was almost there I realized the E-brake foot pedal mechanism was keeping the shaft from coming out the last 3/4" or so... aaaaarrrrgggghhhh!!!!
I wasn't about to give up at that point so I unbolted the
E-brake assembly, removed the cable and pulled the assembly out of my way. Success at last!!! But what a freakin' pain... did I mention there's no way to get into a comfortable positon under there???
I decided instead of replacing the brake pedal lever with a manual unit, (which would mean pulling the one out of my other Ranger... no thank you!!!), I would modify my existing unit and re-install it.
I got the measurements from my other Ranger, drilled a hole in the correct location on the lever and tapped it for a 1/2-13 shouldered bolt. I ran the bolt in from the same side as the factory stud 'til the shank bottomed in the threads and torqued the crap out of it, then I threaded a nylock nut on from the other side an torqued it down.
I cut the bolt head off at the appropriate length, ground it flat and chamfered the edge. Next I cut off the excess threads from the nut side and ground it smooth.
I had to make a brass bushing to step the new stud diameter up to 9/16, prefit the brake rod with black bushing, white nylon washers and brakelight switch to get the location of the hole to drill for the springpin retainer. I removed the pieces, drilled the hole and reassembled everything, it worked great.
I got the brake and clutch pedals back together along with the firewall connector, cut the part of the E-brake bracket that doubles as the drivers side dashboard mount, re-installed that piece and the lower dash access panel and called it a day.
So I finally have brakes again except for the E-brake which I am replacing with a Rover floor mounted hand brake. So much for those simple little mods that "wont take long"...
The above post was copied from my thread in the V-8 Conversion forum:
http://www.therangerstation.com/forums/showthread.php?t=21297
I haven't driven the truck yet as I am in the process of a V-8 swap but the brakes have a hard pedal and feel just like the factory manual brakes in my other 2 Rangers.
Hope this helps!
Mike
