- Aug 18, 2007
They are not lockers. They are limited Slip units that use a clutch pack system. They do wear out over time.
Thanks for the heads up, this swap just keeps getting cheaper. I will be about $350 into it assuming the disk brakes don't need any work. The explorer rear end I am getting is a 98 with 100k, I looked at it yesterday and everything appears to be in good condition is there anything I should pay extra attention to prior to paying for it. I have not pulled the back cover yet but they said that they would pull it and take a look. It has the locker as well. I have a question that you guys maybe able to answer, the rear end that just went out on me is a 7.5 with a locker but I have never felt the locker work. I have this pickup for 14 years and drove it over 200k and have always thougth that it had an open diff but the tag indicates its a locker. Are these lockers so mild that you don't notice when they are working?
Ford never put a locker into any of it's RBV's you might have a Trac-Loc which is a clutch type LSD system, and if the clutches are worn out then, yes it can feel just like an open differential...
General rule of thumb is after 100k consider them open.
I would stick new clutches ($75ish) and axle seals in it before I installed it. The axle seals are $3 each and since you have to have the axles out to put new clutches in it they are right there.
95 XLS..... we had 2 of them with Drum brakes at Fairchild AFB. And Bill's in Spokane WA had 4 or 5 of them laying around.95-01. After 01 the Explorer went to an independent rear suspension. I've never heard of a 95 Explorer coming with drum brakes.
I've had two RBV's with Trac-Loc's; a BII and my Ex, and both had well over 150k miles and the LSD was still tight... I guess I'm just lucky then...
