ABS light on...then off
jonesy2006
10+ Year Member
Hello!
I have a '96 4.0 L. 4x4. Whenever I make sharp turns (usually) my ABS gauge light turns on and stays on until I shut the engine off. The brake fluid level is good. When I turn it back on, the light disappears. Any ideas?
Thanks!
Hello!
Thanks!
You have a bad wheel speed sensor. You will need to have it put on a scanner to see which one it is? Unless you only have rear wheel ABS, then it would be the sensor on top of the rearend.
