easiest way to get a lil bit more travel on the front of my 87?
BEEFKING69
Blountstown, Fl
what would be the easiest and cheapest way to get more front wheel travel on my 87 ranger? remove sway bar? extended rad arms? if i extend the rad arms how much longer and how would i extend my stock arms cause i cant afford to buy any. any help would be awsome :icon_thumby:
remove the sway bar and tie the radius arms to the tranny crossmember
At stock height removing the sway bar will help a fair bit. Extended radius arms won't really help much at all on a stock truck, plus I think they will actually hit the frame on full compression.
If you remove the sway bar your droop will be limited by the length of your shocks.
