1989 ranger motor swap
odley2001
cincinnati ohio
i have the chance to get a 2.3 duratech out of an 03 ranger or an 97 4.0 engine, i know i need the wiring harness and computer to do the swap, and was planning on using the original 5 speed behind the 2.3 in the 89, any ideas, suggestions or tips and what engines would bolt to this trans, check tech and didn't seem quite sure what would go with the original trans
thanks
scott
odley2001
the 2.3 would bolt up...and you will need the dash from the 2003 or the 97 to make them engines work
just all the wiring from the dash? what would be the best swap (easy side ) to replace the original 2.3
thanks
scott
No, the 2,3 will not bolt-up the 2.3DOHC does NOT use the same bellhousing as the "Lima" engine that you have in your '89.
AD
so i guess i should go with the 4.0 will it bolt up to the trans and what else would i need to do a complete clean swap
thanks
scott
I also have the poss of getting a 3.0 out of an 01 ranger any ideas?
thanks
scott
The 3.0 and 4.0 have different bolt patterns than your transmission.
If you do any engine other than another Lima 4 cyl, you'll need the transmission too.
so the 4.0 will not bolt to the original trans?
thanks
scott
odley2001
