duratec's that came with 4.10s
jax4bangin
WESTMINSTER CA
if ur truck came stock with 4.10 gears, what rpm are u at @65 mph? in 5th gear or overdrive
yea im jus curious to see wat the duratec's with 4.10 gears and stock tires crusing rpm is.. im plannin on puttin in some 4.56s in tomorrow along with my 30" tires and my actual ratio (according to the calculators in the tech library) will be 4 to 1 (4.10)
My 09 with manual trans and stock tires (225/70R15) turns 2750 @ 70 mph so I would figure its probably about 2500 @ 65 mph
how do you tell what rear end you have???
Yes, I have the 4.10 rear gear
