- Feb 24, 2009
Loosen transmission top cap and shift mechanism
Remove top cap
Loosen and remove tailhousing
Once the tailhousing has been removed, remove the staked nut from the mainshaft. A hammer, cold chisel and a pipe wrench will come in handy here.
With the tailhousing removed, tap here to remove mainshaft end bearing
An alternative method is to use a prybar and a hammer with a brass or aluminum drift, or a custom gear puller, or possibly a slide hammer to pull the mainshaft end bearing. This technique worked for me, although it is easy to chip gear teeth by prying against them.
Remove top cap
