lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
5-speed or auto... how dare you ask that question of me. Pfft, run along now, you know darn well that I love the manual transmissions.My rear shackle hangers got replaced on my 96 before i bought it. It seems common with this generation of trucks. I put 3/4ton springs in mine because 3 of the leafs were broke anyways. Gave the truck a much more aggressive stance and it will carry alot more of a load.
Is that truck a 5sp or automatic? If its an automatic make sure you change the fluid and filter in it soon.
These trucks really seem to have no weak links in the drivetrain. If i had to guess at something to go out 1st under hard use it would probley be the rear end. But if the wimpy lil 8.8 does go out a 9inch from a 80-84 F series will bolt right in.
later,
Dustin
Yea, I was thinking 3/4 ton springs, just not sure if I should try tackling the task of taking both spring packs completely out or just pop the centering pin and build a pack under the main.
On another note, I just filled up all of the tires on the truck... two front tires had ~28 psi, two back tires had ~17 psi and the spare had ~10. Is it really that hard to check your tire pressure and fill it when needed??
