new sub box
stockfornow
eau claire wi
just got done with my new box running a single 12
new sub box
new sub box
Interesting... I had no idea Master P had his own line of sub woofer series. One of my old time favorites was probably Young Bleed, his first album was actually pretty good. How does it sound? I am also curious on what amp, is it a Power Acustic?
Pete
not much of a bazooka fan
+1
I'am so pissed, I dont want to buy a sealed box because its $70!. How would you think I could make a sealed box with the hole of square subs, that will fit in my extended cab?
+1
build your own? MDF is cheap
+1
building your own is cheaper it cost me $40 to build mine
fantastic,the issue I ran into is how do I make holes for a sub like this one:
http://www.kicker.com/solo-baric_L5
if you bought the sub new it should have came with a template to make the cut for the sub. If it didnt make your own by tracing the sub on paper then measure the amount of lip on the sub and make an inside square that much smaller cut out the inside then that will be your template for your sub hole
a full sheet is like 40$ for 5/8 and thats enough for like 2-3 boxes
square subs imo suck. they dont produce bass as well as the round ones. but hey its just mo
