- Jan 6, 2009
The story so far...
Bought an '87 Ranger with a 2.9L last August. The truck was purchased from a friend in Tucson Arizona. At the time the temp gauge was reading high. The P.O. told me it had been doing this for a while. Over the passed 2 years he had replaced the rad, pump, thermostat, and sending unit for the gauge to try and remedy the problem. Nothing worked, but he was curtain the motor was not running hot.
About a month after purchase, the truck overheated during a trip from Phoenix to Tucson. I was able to make it to an auto parts store where I changed the cap (after cool down), and replenish with bottled water. It was enough to get me to Tucson.
The next day I flushed the cooling system, replaced the thermostat (180 degree) and added a bottle of Water-Wetter to the coolant mix. After warm-up, the temp needle read square in the middle of the gauge. Okay, problem solved. A day later, the temp gauge refused to work; the needle never came off 'C'.
In December, I used the truck to tow a car and about 500lbs of tooling from Tucson to my home in Ontario Canada. By the time I reached Oklahoma City it was cold enough to need heat inside the cab. There was nothing coming out of the vents. I changed the thermostat again (190 degree this time). Nothing. At my next fuel stop, I placed a piece of cardboard over the grill. Nothing. Despite being nearly overloaded, climbing over dozens of hills and mountain passes, the truck would not heat up. At one point I used 4WD through a snow storm. Still nothing. Aside from this, I had no problems with the truck during the trip.
It is now registered in Canada. I have been driving it without heat since my return last December. This evening, I finally found the time to troubleshoot these issues. During a short drive to my shop, I noticed the throttle response was sluggish. The temp gauge then spiked toward 'H'. I pulled over, shut it off and popped the hood. The radiator had sprung a leak and was probably overheated. Did I mention it was -15C at that point, with a wind-chill of -22C; I had just herd to the weather report before stopping! WTF is going on!!!
I waited for it to cool down, topped off the rad with windshield washer fluid (the only thing I had that wouldn't freeze overnight), and nursed it back home. Still no F***ing heat in the cab, of course.
At least I know my engine temp and the intermittent indication problems are not related. What is strange is that both hoses to the heater core are warm despite the engine temp. It seems I have 3 separate problems.
Tomorrow: flush coolant, new rad, new thermostat (for the forth time in 6 months), probably a new temp sender, fresh coolant (without Water-Wetter) and a close look at the heater core and ducting.
Am I forgetting something? Any suggestions?
Thanks
Thanks
