================================================Hey I was just wondering if ford ever actually made an extended cab ranger with the 2.3 engine?
I just swapped a 2.3 into a 2.9 ext cab and I see now that the driveshaft yokes are different.Thanks!
I've swapped a 2.3 into an Xtended cab that had the 2.9 too...and, yes, the shafts and connectors are different...
Took me three tries to get it right, and ended up having a shop weld the back connector onto the shaft...it was an expensive endeavor...because I actually bought two different drive shafts at $100 a pop...and then paid another $50 for the weld...then had to replace a U-joint...
