- Feb 10, 2009
- Age
- 35
- Sanford, NC
Its does matter because the guy that sold it to me three years ago must have installed the syncro wrong when he replaced the motor. The only possible causes for my eng light are out of sync cps or an ecm failure or incorrect perameters set in ecm. Especially with this code by itself, if i had two codes it would be easier to narrow the prob down.
Ok my bad I see now. Because you have a code, in order for you to get it correct you would have to set TDC compression. I didn't have a code I just figured I would replace it based on the response I got and it turned out to be right.
I went back today and filled it back up...6.5 gals....and i'm going to drive like I normally do, not pedal to the metal like I was the other day...
